Sky+ remot and Tv settings
Discussion in 'Sky Digital TV Forum' started by potshot, Sep 11, 2005.
  1. potshot
    potshot
    Jan 31, 2004
    2,039
    63
    +181
    I have lost the settings in sky+ remote for my TV, does anybody know how I re-programme the remote.
    Mike
  2. JayCee
    JayCee
    Jan 20, 2004
    20,326
    Lanarkshire
    +1,953
    You can get the settings from your Sky+ by pressing the following keys on your remote.
    "Interactive", "Sky Customer Service", "Technical Assistance", "For All Sky Remote Controls", "For Your Sky+ Remote Control", "How Can I Setup My Sky+ Remote Control", "Programming the Sky+ to Operate your TV".
    An A-Z of all TV manufacturers then appear.......just place the on-screen arrow against the letter which corresponds to the first letter of your TV make using the arrow keys on your remote and press select.
    Scroll to your make and take a note of the code nos........one of which should operate your set.
    Another guide can be found here
  3. potshot
    potshot
    Jan 31, 2004
    2,039
    63
    +181
    Thanks Jaycee. Couldn't find my tv on there, toshiba 36ZP38, tried code 536 but it didn't work. Looked for my tv under 28 inch and 32 inch but not there.
    I will phone sky and see if they know the code.
    Mike
    Phoned sky and it was code 536 but needed to reset sky+ remote to factory settings first code 999. All working now.
    Thanks for your help.
  4. smiffy333
    smiffy333
    May 10, 2005
    1,742
    48
    +57
    Potshot
    Coincidentally had exactly the same thing happen to me yesterday.
    Tried everything to get the TV working again and was assuming a new remot was in order.
    But just checking the forums and tried the rest mentioned and all ok again.
    :clap:
  5. The Foot
    The Foot
    Dec 17, 2004
    256
    16
    How do you reset remote?
  6. JayCee
    JayCee
    Jan 20, 2004
    20,326
    Lanarkshire
    +1,953
    If you mean "how do I program it to operate my TV" see the second answer in this thread............or take a look here
  7. gordnil
    gordnil
    Nov 22, 2004
    43
    just wondering how you "reset sky+ remote to factory setting"
  8. SamRadford
    SamRadford
    Jul 12, 2005
    3,965
    103
    N. Yorkshire
    +309
