Sky + recordings failing
Discussion in 'Sky Digital TV Forum' started by ridd, May 20, 2004.
  1. ridd
    ridd
    Jan 15, 2004
    111
    16
    nothamptonshire
    Recently i have had quite a few recordings fail. It started out as recordings that would lock up and recordings that say "loss of signal" as the reason.
    The signal is fine and has always been fine.
    Tuesday even 3 recordings failed (i actually watched one of the programs).
    I was given "reason unkown". Has anyone had this kind of problem?. The box isnt modified in any way. But isnt plugged into the phone.
    Any ideas ?
    Mark
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Swap the LNB connections over, it may be that the signal is weaker via one cable and prone to dropouts which may cause a failed recording while the same program was fine on live viewing.
  3. MonkeyBoy
    MonkeyBoy
    Aug 4, 2000
    115
    Didcot
    +10
    I have been having this problem in that last two weeks, there does not seem to be a paten to it, but I have now missed all the new Top Gear shows because of it.
    It is not anything to do with the dish or cabling as I have had this checked out.
    I have also been getting more problems with picture brake up on playback of recording (This can be fixed doing the software update mostly).
    Steve
  4. ridd
    ridd
    Jan 15, 2004
    111
    16
    nothamptonshire
    Yup Mine has only been doing this for the last 2-4 weeks. it worked without fault before then.
    I did a house keep format thing last night so ill see how it behaves from now.
    Mark
