Sky + recording won't play.
Discussion in 'Sky Digital TV Forum' started by Keithcun, Feb 11, 2005.
  1. Keithcun
    Keithcun
    Jan 23, 2005
    152
    +4
    Hi.
    Over the last couple of months I have had a few problems with trying to play recordings on the Sky+.
    I have a V2 Pace and is just coming upto 12 months old.
    On the planner,the recording is showing up OK,and with the correct time of program eg 63 mins and the wife has even watched the program as when I have come to view,the program is marked at viewed.
    But no matter what I do,it just won't play.I've tried playing from the start,end and user defined.As soon as I try to play,the box/controls lock up and I have to press the Sky button to get out of the EPG.
    Anyone have any ideas or solutions.
    Thanks Keith.
  2. mouzie
    mouzie
    Sep 24, 2004
    9
    Keith,
    I'd get a sky engineer round sharpish before your warranty is up. The call centre will get you to jump thru loads of hoops b4 they agree to sending one but be insistant.
    Similar thing used to happen to mine but that was the thin end of the wedge, eventually the whole thing went kaput, wiping everything off my sky planner. Because I'd just gone past my warranty having to pay £65 for a callout.
    Good Luck]
    Mouzie
