Sky+ & recording to a Sony DVD Recorder
Discussion in 'Sky Digital TV Forum' started by videonasty, Aug 24, 2005.
  1. videonasty
    videonasty
    Feb 12, 2004
    2,274
    West Midlands
    +39
    I've just subscribed to Sky+ & before that I had a Freeview box. If I wanted to record something of Freeview, I had to program the Freeview box to start the film/program & then set a recording time on my Sony GX300 DVD recorder. The DVD player channel was Line 3 & played what I wanted to be recorded through this channel. Alternatively, I could put the DVD player in Synchro mode. This would automatically know there was a signal coming from another source & start recording through Line 3.
    My question. Is this the same for Sky+, as my scart leads are connected the same way as the Freeview box was, to the DVD recorder?
  2. videonasty
    videonasty
    Feb 12, 2004
    2,274
    West Midlands
    +39
  3. greeny
    greeny
    Just use the Sky Plus box to do the recordings. If you then want to copy stuff to the DVD recorder use the Sky+ 'copy' function. Just set off the copy when you go to bed and leave it to record.
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Yes that's by far the best method.
  5. videonasty
    videonasty
    Feb 12, 2004
    2,274
    West Midlands
    +39
    Last night I decided to back up some movies from Sky onto my DVD Recorder. I started the process & left it over night. This morning the Sky+ box was in standby, is this normal for the box to do this after using the Copy function?
