Sky+ Recording stopped working
Discussion in 'Sky Digital TV Forum' started by lewisn1, Dec 23, 2003.
  1. lewisn1
    lewisn1
    Dec 23, 2003
    57
    Wales
    Has anyone had a problem with sky+ recording???
    A few days ago I noticed the stuff I put in my program planner as a reminder had stopped appearing.... also a few things I had to record were still there! to be recorded!!!! No message saying why it wasn't recorded...nothing.
    I have since tested it again and again. same problem...
    I phoned sky, they talked me through the standard resetting the box, nothing.....i thought not!!! they were not much help.
    I then demanded they come and replace the box (with a new one not referb one) as mine is only 2mnths old. they made no promises as it depends what the bloke has on the van!!!!! i told them i would not accept a referb box and could he make a note on my call so i wouldn't be wasting the sky man a wasted trip. Noooo to much effort for the friendly skyman on the phone :-(
    I said as its xmas and my record does not work I asked about compensation, the bloke laughed at me..... i gave up at that point and would just be happy with a working sky+ box.
  2. bob mushroom
    bob mushroom
    Jan 26, 2003
    790
    +22
    Mine has just done this tonight!!! How annoying I'll be ringing tomorrow
  3. satch
    satch
    have you tried a full system reset ?
    services
    4
    0 then 1
    select
    7
    select
    or try a software update?
    unplug from mains hold backup on front of sky box then power on hold backup in for approx 20 secs .
    or offer the sky man a cuppa, bacon roll,mince pie etc,etc and im sure he would put a new s+ in for you trust me!;)
  4. lewisn1
    lewisn1
    Dec 23, 2003
    57
    Wales
    Satch,
    Thanks for that but i checked with sky and i do have the latest software version. And mince pie and a cuppa!!! i dont think so if its the same bloke as last time, he was hopeless.
  5. wozwebs
    wozwebs
    Jul 10, 2003
    1,196
    +111
    Mine did this on Xmas day. All my saved progs vanished & couldn't record. I called Sky who I didn't think would be there on Xmas day and they talked me through a system reset. Worked fine after that.
  6. lewisn1
    lewisn1
    Dec 23, 2003
    57
    Wales
    I have had a new box from a happy sky bloke and all seems fine at the moment.
    Will see how it goes, finally I can record stuff again :smoke:
