Sky + Recording Quailty
Discussion in 'Sky Digital TV Forum' started by Rookies, Jan 21, 2003.
  1. Rookies
    Rookies
    Jan 4, 2003
    5,681
    +542
    Ok, I am wondering if the programs or what ever that get recorded on Sky plus when played back is the same Quailty we get when watching live SKY? or is reduced a bit?
  2. bobbles
    bobbles
    exactly the same quality, DD5.1 on sky movies
    it records the data stream so u can even get up subtitles etc
  3. bobbles
    bobbles
    oh and it doesn't record the red dot
    fantastic
  4. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
    It's exactly the same as if viewed live.
    The Sky+ box simply stores the same digital signal without compressing it at all.
    It's the dog's....best thing I've bought in ages and that includes my plasma.
    Cheers, CC
  5. bobbles
    bobbles
    Sky+ is marvelous
    fantastic
    but, it is annoying on certain points because you just think if only you could do ...
    and why doesn't ....
    just minor tweaks that you would think would be easy to implement
    dual record is out soon
    I just wish they would put on some editing features on the HD
  6. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    +16
    Yeah dual record would come in handy but I doubt they will ever incorporate any editing facilities, and even if they do I guess they would be pretty basic as they would want to keep the system easy to use.
    For my needs it's just dandy.
    Cheers, Lee
  7. Rookies
    Rookies
    Jan 4, 2003
    5,681
    +542
    I think I wait for the duel record then. But I bet it be more money for the box??
    Any ideas when it out and have SKy + said they doing this or is it coming from other people
  8. bobbles
    bobbles
    the dual record will be available via a software update available around March. Sky told me Late Feb!
    Pace are meant to be releasing a new sky+ box with this softwarfe update already onboard. However, it is meant to be only a cosmetic upgrade, cheaper for pace to produce.
  9. Rookies
    Rookies
    Jan 4, 2003
    5,681
    +542
    So are you saying if I got sky + now and all use sky + owners will be able to get out box software updated to get the duel record? Does it not put the subscription price up?
  10. bobbles
    bobbles
    yeah no extra cost
    sky+ very often update the software
    the last software update was just before xmas it installed instant rewind
    a great feature
    Sky+ are doing a fantastic loyalty offer at the minute
    mine was
    199 for sky+
    60 installation + relocation of current box to bedroom
    15 extra per month
    a normal second box costs you 125ish and 12 extra per month
    without the loyalty offer it is, I believe
    299 box, 70 installation, 10 extra p/m sky+ 12 extra p/m second box
    I do not see the point in waiting for the new box as update will only be cosmetic, smaller box.
    There are rumours that a 80GB HD will be available on new box, currently 40GB (20hrs ish recording time)
    but this update will certainly be available for current owners too
    you can update to 120Gb HD quite easily, I am told, but this invalidates your warantee so I will wait till mine is nearly up
    hope this helps
    get sky+ it really is fantastic, no more VHS
  11. swarrans
    swarrans
    Dec 21, 2001
    409
    16
    Kent, UK
    Whilst I'm not questioning the original posts, but I am rather surprised that the quality of Sky + recording is EXACTLY the same as the original recording....
    I only say that because Tivo uses MPEG which is a compressed format and does impact the recording quality AND it seems to take up about the same space on the hard drive as the Sky + system (approx 10 hours for 40GB).
    The Tivo recordings look very good on "normal" TVs, but I understand can look a bit rough if you've got a huge plasma!
    Simon
  12. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    SKY+ records the bitstream data onto the hard drive before it get's to the mpegII decoder so it does not matter if you watch a program "live" or at a recording of that program later.
    The output of the SKY+ has only passed through the mpegII decoder once so there is no difference between the final quality.
    TIVO takes the mpegII decoded output of a digital source and then re-encodes it using mpegII to record onto it's hard drive, it then has to decode it on playback. It's these multipule operations that decrease the overall picture quality, repeated encoding and decoding using mpegII of any material always results in a lowering of picture quality.
    As you say the Best setting on TIVO is perfectly acceptable for recording good quality pictures but it can not match the SKY+ method and SKY+ does not record interactive elements (red blob) and on playback you can still choose the subtitles and aspect ratios you want just like a live recording.
