Sky+ recording + hard drive
Discussion in 'Sky Digital TV Forum' started by da02uk, Mar 18, 2005.
  1. da02uk
    da02uk
    Jan 6, 2004
    150
    Manchester
    +4
    Is it possible to record films or programmes using the sky+ box and then transfer them onto the hard drive on my computer for the purpose of burning them onto disc?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Not in the manner you want:)
    You can only do this by connecting the analogue video/audio outputs of the SKY+ to a PC capture card or using a DVD recorder to create a portable copy.
    If you have a v1 SKY+ then a SDI mod will do the same but at higher quality.
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    The reason you can't do this is because the data is stored on the drive in encrypted format, and can only be played back through the decoder in the Sky+ box.
