Sky + recording fault
Discussion in 'Sky Digital TV Forum' started by blackcat, Jan 28, 2004.
  1. blackcat
    blackcat
    May 11, 2002
    19
    north-east england
    Anyone had a "system fault" message appear on screen when using the recording feature ?
    Phoned Sky about the problem and reset the Sky + box, but still the same fault. Engineer visiting Saturday hopefully to rectify the problem !
    Bloody box is only 2 months old !! Purchased from Comet.
    The cooling fan on the hard drive has been noisy the last few days or is that just me imagining it !
    Any feedback would be appreciated:smashin:
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    As I understand it the "system fault" message is pretty terminal, odds are that they will do a straight box swap perhaps with a reconditioned unit so beware.
  3. STOWITBELOW
    STOWITBELOW
    Nov 17, 2002
    1,578
    48
    Lancashire
    +49
    I should be aware rather than beware. A working reconned unit must be better than a broken new one! It should be as good as new though, & is worth examining / testing whilst the engineers present in case of problems. (If there are you'd have grounds to demand a brand new replacement I would say)
  4. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Actually my first choice would be replacement with a brand new unit and secondly my unit being repaired. Replacing a broken SKY+ which is within warranty with a recon that could be over two years old is totally unacceptable.
    So yes be aware of the procedure but beware that they don't steal your hardware and replace it with old kit.
