Sky+ Recording Errors
Discussion in 'Sky Digital TV Forum' started by thomas884, Jul 20, 2005.
  1. thomas884
    thomas884
    I am also having recording difficulties with my SkyPlus. Reocrding does not work via the Planner but will record if I choose direct from screen. When using the Planner as well as not recording it then tells me there is a technical problem on that channel. I then have to power the box off to get the signal back, This happens mainly with BBC1/ITV channels. I have done the housekeeping and also a full system reset ater contacting Sky. Has anyone had this problem or is it a sign that the HD is on its way out?
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    What does the page showing the signal strengths & qualities say ?
  3. thomas884
    thomas884
    There is a bar on the first one to about 75% and a bar on second one to about 50%. It says on Input Network ID 0002, Input Transport Stream 07d4, on Input 2 Strength and Quality there is just empty boxes.
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Switch over the connections LNB1 and LNB2 at the back of the box. If the signal strength in box 2 comes up, you either have a faulty LNB, or a faulty cable from the LNB. If LNB2 stays at zero, it's either a faulty hard disk or tuner (more likely to be hard disk). Go into the "secret menu" (Services, 4, 0, 1, Select) and do a "master reset". This will erase the hard disk contents !
  5. thomas884
    thomas884
    thanks and will try that later when I can get some help to move the TV (broken leg restricts me!). I have done the full system reset again so will see what happens. Will let you know how we get on.
  6. thomas884
    thomas884
    Hi Nick
    I turned out to be a faulty dish which has been replaced by Sky today. Thanks for your help and advice
    Maureen Thomas :thumbsup:
  7. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Glad to be of help. :thumbsup:
