Sky+, reclaiming disc space
P
Pete at 96
I have been through the procedure, Services - System Setup, and then 0 - 1 but I can't get it to work. I eventually got hold of someone on the phone (Bangalore it would seem... it used to be Scotland...) who could only suggest that I press 0 - 1 very quickly, which I have tried many times to no avail. Any suggestions?
And whilst on, it seems to me that Sky Customer services are seriously deteriorating... why are the telephone numbers given out on screen all wrong, surely it is the simplest thing to get these right on their own screen?
Cheers,
Pete
andyr300
services 4-0-1, then possibly there is a push of the 'select' button.
then you'll want option 7.
P
Pete at 96
Fine, but it won't get past 4 .... pressing 0-1 doesn't work, and I've tried it dozens of times.. what am I doing wrong?
Cheers,
Pete
kenedin
Press Services, 4, 0, 1, & Select. There is no onscreen response as you press the '0' & '1', just press the sequence. When the Installer Setup appears, use Option 7 - Planner Rebuild.
P
Pete at 96
Thanks, guys, that's done it.... I didn't realise that you had to hit "select" before there was any onscreen response.
Thanks a bundle again,
Pete
