Sky Reception
Discussion in 'Sky Digital TV Forum' started by baldie, Sep 17, 2004.
  1. baldie
    baldie
    Jun 29, 2004
    52
    I recently had Sky + installed and the existing box moved into a different room, the reception on sky + is perfect, however, the old sky box is awful and seems worse on some channels than others, for things like Sky Sports its unwatchable, it seems to allow a frame a second, it can't be the dish as Sky + works perfectly. Is there anything I can do on the box that may help?
  2. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    Have you checked the signal strength and quality - it might be that the cable isn't connected to the LNB correctly as it's a different cable to that going to the Sky+ box.
    HTH
    John
  3. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    The two STB's are being fed two seperate (3 if you count two tuners in SKY+) feeds from the Quad LNB down their own seperate cables. It is quite possible for one feed to be perfect while the next one is not, the quad LNB being four seperate units in one case.
    Connect the standard digibox to one of the LNB cables that feeds the SKY+, if the reception is good then you have a problem with the LNB or cable. If the picture is no better then the digibox tuner could be on the way out.
