Sky radio channels
mannys_av
I'm hoping someone can help. Just bought a plasma panny g10. We listen to sky radio channels a lot through our tv. Is there a way of listening to the channels via tv speakers without having the display constantly on as I'm worried about burn in.
If it's possible to connect it to an amp to achieve this pleease advise. I have an old technics amp I could use
thanks
manny
paulr2006
You can't listen to sky via the TV without the screen on, you could however connect the Audio out (L & R Phono) from the Sky box to an Amp & speakers :)
F
Fatwaz
yes tv can be off just sky box needed to be on with amp and speakers
paulr2006
Would that mean I could leave the tv switched off? Sounds like a better option
yes as long as you have tuned to the station you require, i.e. use the screen to navigate to the channel (unless you know the channel number you want in which case you do not even need to turn the TV on) :)
