Sky Radio Bitrate
Discussion in 'Sky Digital TV Forum' started by sacd, Apr 18, 2004.
  1. sacd
    sacd
    Feb 19, 2004
    297
    Cardiff
    I'm sorry if this has been covered before but I've just been listening to Classic FM on Sky + and I am amazed at the sound quality.
    I have 2 questions.
    1) What is the transmission format (Mpeg 2?)
    2) What is the bitate and is there anyway I can find out the bitrate of a given radio channel?]
    Thanks!
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    1) yep
    2) Might be a bit outdated but it's the only source I have found..Bitrates
  3. sacd
    sacd
    Feb 19, 2004
    297
    Cardiff
    Does this mean that sky+ will give as good (if not better) radio reception than a DAB tuner? In some cases the bitrate seems to be better for sky!
    Of course I am using the optical out.
  4. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Digital satellite does on average have higher bitrates than DAB, I suspect the carriage is cheaper and there is a hell of a lot more of it so broadcasters don't have to use lowbitrates on Dsat like they do on DAB. DTT should also produce good quality audio although has fewer radio channels due to the limits of the platfrom.
    DAB in my opinion has been a total let down quality wise.
