Sky Radio and RP TV
J
Jingy
I have a Toshiba rear projection TV connected to Sky Digital,
my question is that I like listening to some of the radio station on sky digital but am concerned about creating a burning effect on my screen which I understand occurs if a still image is projected on to the screen for long period of time.
Is it possible to listen to the radio in any way without having the TV on..i.e through an Amp.
Is it better to have the contrast and brightness high or low to reduce the buring effect ??
Bert Coules
Perfectly possible and a good idea. What make is your Sky digibox? It will almost certainly have two phono sockets at the back which carry the sound output. Connect these to an amplifier and off you go.
Given a listing magazine for programme details and a good memory for the channel numbers of the radio stations you like listening to, you don't need to turn on the TV at all.
Bert
www.bertcoules.co.uk
rhinoman
Definatly lower the contrast and brightness, burn in can occur very quickly on RP tv's with it set too high and a static image. Do as Bert says and connect it to an amp and then turn the tv off.
J
Jingy
Thanks for that I will give it a go.
My Sky Digibox is Philips.
