Sky questions
Discussion in 'Sky Digital TV Forum' started by MonkeyNutz, Nov 6, 2005.
  1. MonkeyNutz
    MonkeyNutz
    Mar 19, 2005
    163
    +4
    Hi, i`m looking at getting sky, I tried phoning them but after half an hour holding the line i got fed up and figured I`d get less biased answers here. Anyway my questions are:
    what video outputs do the boxes have? I`m going for the standard sky box.
    What audio outputs do the boxes have?
    Sky say they have 5.1 support. Is this only on the movie channels and pay per view or do films on normal channels, say sci fi for instance, use it too?
    Do the boxes only come in white or can you get them in black?
  2. paulst10
    paulst10
    Dec 16, 2004
    12,878
    Essex
    +2,313
    video outputs .. composite, svhs and scart
    audio ouputs .. analogue only unless sky+ then optical as well
    5.1 support is only for sky movies and you must have sky+ and be using a digital optical cable for this
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +272
    Ordinary Sky boxes do not have s-video outputs, only Sky+
  4. MonkeyNutz
    MonkeyNutz
    Mar 19, 2005
    163
    +4
    Great, thanks for the help. When you say scart is it RGB scart? I`m thinking or getting a panny pwd8 plasma and want to get the best possible picture quality.
    the 5.1, if i did go for sky+ would this be available on the pay per view movies?
    And lastly can you get the sky box in black? or is it white only?
    cheers
  5. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    The TV out scart is RGB, the VCR is composite, but will pass RGB through as an iput. There is no 5.1 on pay per view movies and you can't get the box in black which is a real pain
  6. MonkeyNutz
    MonkeyNutz
    Mar 19, 2005
    163
    +4
    cheers for the help. When you get sky, is the box your property or skys? and has anybody tried these places that will paint your kit?
    cheers
  7. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    I think it depends which deal you go for......but either way painting would probably invalidate any warranty or support agreements
