Sky+ Question
Discussion in 'Sky Digital TV Forum' started by matt80, Apr 9, 2005.
  1. matt80
    matt80
    Mar 31, 2005
    20
    Is there any real difference between having Sky+ and having Sky together with a PVR of your own choosing? Would I be accurate thinking that Sky+ is basically Sky bundled with a PVR?
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Can you record one Sky channel and watch another with a PVR ?
    Can you record two prorammes at once, and play back a recording at the same time ?
    Can you set a PVR to record one episode of a soap, and then automatically record every other episode, even if the start time changes ?
    You can with Sky+
  3. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    The key to SKY+ is integration.
    The ease of use is made possible by having the EPG directly feeding the recording sub-system which in turn is directly tied to the digital tuners which allows perfect recording of the broadcast bitstream.
    Those two features make the SKY+ head and shoulders over a SKY digibox connected via scart to a HD based recorder or even HTPC.
    TIVO is the only true PVR and even that would benefit from having SKY or NTL/TW digital tuners/decoders integrated into it's hardware as it is in the US with DirecTV units.
