sky+ question for my wife
Discussion in 'Sky Digital TV Forum' started by phil5743, Oct 1, 2003.
  1. phil5743
    phil5743
    Apr 13, 2003
    401
    28
    Ongar, Essex
    +27
    My wife is concerned about any extra cables with sky+ ! Does it just connect in the same way as the existing digibox (to dish outside) Thanks
  2. lmccauley
    lmccauley
    Oct 24, 2000
    3,319
    Newcastle
    +216
    There are two cables running from the dish to the Sky+ box instead of 1.
    Cheers,
    Liam
  3. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Some installers will use a shotgun cable (Two cables in a single sheath) which would probably be suitable for the missus but for longer runs the general concensus is that two single cables offer better performace.
  4. phil5743
    phil5743
    Apr 13, 2003
    401
    28
    Ongar, Essex
    +27
    Do you think I can safely assume that they will run the cable through the wall near/adjacent to the existing one (she is worried as we have just decorated!)
  5. UrbanT
    UrbanT
    Jan 6, 2002
    12,881
    Aldershot, Hants
    +3,038
    Had ours installed Saturday, thats exactly what they did. Drilled a new hole right next to the existing one. My missus thinks its great (but still doesn't understand how it works ;))
  6. lmccauley
    lmccauley
    Oct 24, 2000
    3,319
    Newcastle
    +216
    That's what they did with mine.
    It's a great device. So simple to use. If you're browsing the EPG and you see a program you want recording, then you just highlight it and press the (R) button. Want to record each episode? Press the green, Series-link button. Easy peasy!
    Cheers,
    Liam
  7. UrbanT
    UrbanT
    Jan 6, 2002
    12,881
    Aldershot, Hants
    +3,038
    Couldn't agree more Liam. Sat doen on Sunday evening and picked all the programs I wanted to see for the week. Took 10 minutes and I've actually seen programs this week I missed last week coz I forgot they were on. I never used the video but this I love :)
