Question Sky Q with a 4K splitter?
Discussion in 'Sky Digital TV Forum' started by 99P, Dec 11, 2017.
  1. 99P
    99P
    Previously PPP
    May 15, 2007
    2,967
    +347
    Does anyone know of a 4K HDMI splitter that will definitely work with Sky Q? I want to split the signal to two 4K TV's.
    I've tried two splitters from Neet, one of which specifically said compatible with SKy Q, but they didn't work. They work fine for 1080p but not 4K.
    I now there are expensive £100+ solutions but I was hoping to do this for less.
  2. Deleted member 92943
    Did you ever find a good splitter mate?
    I'm after a 1 in 2 out automatic splitter. Doesn't need to support 4K but my older splitter (which is 4K) won't work anymore. Apparently it's because the HDCP they implement on Q
  3. 99P
    99P
    Previously PPP
    May 15, 2007
    2,967
    +347
  4. Deleted member 92943
    Thanks mate, I’ve ordered on and will give it a go.
    My setup is long winded as what I want is the SKY Q going through the Xbox and then split to two rooms so I can also watch Blurays easily. It all used to work before on an old splitter but doesn’t work now even though I only want it all in 1080p
  5. Deleted member 92943
    Got the splitter and it works an absolute treat. I have Q routed through the Xbox one S and then split to two TVs meaning I can also play games and watch movies without any issue.
    Phoned SKY and already cancelled multi screen. That's another £12 a month saved on my bill.
  6. sounddog
    sounddog
    Dec 11, 2002
    3,448
    107
    Leicestershire, UK
    +480
    Don’t you loose UHD if you don’t have multi-screen?
    Oh ignore me, it was the OP who wanted 4K...
