wilson85uk
- Joined
- May 4, 2014
- Messages
- 23
- Reaction score
- 3
- Points
- 14
My mother has just upgraded to SKQ Q from the older HD which used the larger boxes and I'd share the SKY TV with my bedroom via a wireless video sender, worked no problem. Although it was only a standard def signal taken off the scart feed, it was perfectly watchable on my 43" 4K TV.
According to what the sky engineer said "you can't piggy back off Q". They then mentioned the option of a sky Q mini box.
I know I can't connect the sender directly to the Q box but I thought all I'd need todo is, add an hdmi splitter, then connect to living room TV as normal, connect the other hdmi cable to an "hdmi to composite converter" and connect video sender and all is sorted, would this work ok, whose, right sky or myself?
I personally think with the sky engineer, their not allowed to support sharing a single box, as your meant to pay sky for an additional.
