Sky Q to 2 TVs
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Stuarty, Feb 23, 2018.
  1. Stuarty
    Stuarty
    Feb 23, 2018
    2
    4
    Bangor
    I recently have got a SkyQ box and have lost my ability to use a magic eye and coax cable to show the display on 2 tvs.
    I was looking into options and wondering if there was a way of using HDMI to CAT 5 to send the signal to both tvs. Anyone any experience doing this? is it even possible? Any recommendations of equipment?
    One TV will be in the room with the sky Q box so remote control use in this room is not an issue. The other tv would need some way of sending the remote signal back also- is this even possible?
    All advice gratefully received.
  2. chopples
    chopples
    Dec 24, 2009
    1,640
    116
    Wirral
    +801
    This can be done mate, you would also need a 1 in 2 out hdmi splitter with the recommended spec. For the remote you have a few options.
    You could run a infrared repeater.
    This will depend on distance but you may find the touch Q remote works anyway (it uses bluetooth). You can then just use the bog standard remote in the room with the box.
    Its been a while but I think you can also control the box with the Sky Q app
    cheers
  3. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,561
    Redditch
    +4,190
  4. Russ_64
    Russ_64
    Jan 20, 2005
    564
    2
    London
    +288
    Any reason why you did not consider getting one Sky Q Mini? It has many advantages but comes at additional cost.
  5. chopples
    chopples
    Dec 24, 2009
    1,640
    116
    Wirral
    +801
    Probably the £99 upfront then £12 a month. If both tvs are seldom used at the same time it’s an unnecessary expense which adds up over time
  6. TJT1
    TJT1
    Jul 29, 2011
    4,782
    East Sussex, UK
    +1,127
    Sounds like a fair reason to me.:D £243 for the first year!
  7. Stuarty
    Stuarty
    Feb 23, 2018
    2
    4
    Bangor
    The 2nd tv is rarely used so wouldnt warrant the extra month expense. We are happy with freeview and firestick for but have a bit if recabling to do for main tv anyway so thought i would explore options
