Ronnie3
Hi, hope everyone is well?!
I wish to replace a TV VERY flat against the kitchen wall. It is connected to a Sky Q mini box which I do not want behind the TV as I want it FLAT, I don’t want a wall mounted Q box to the side as it looks a bit ugly. The other side of the wall comes out within a cupboard in the utility room - is there a magic eye or similar method which could work? Is there another option? Which TV brackets would you recommend please? Also, taking into consideration how flat I want it, is there a good option for a sound bar or TV not needing one, which is flat, it can come down lower. Taking any recommendations for frameless TV’s too, 60 - 65” if you wish to rave about your preferences, big budget. Thank you very much in advance
