Question Sky Q single cable installation
k0s7as
I am in the process of ordering Sky Q but I have a question regarding my current setup.
Currently I have a dual sky LNB connected through a Global Invacom Stacker and one cable runs inside the house. Inside the house I use the Destacker to get two cables.
Does anyone know if I can simply wait for Sky to upgrade my LNB and use the Stacker De-stacker as previously or do I need something like a universal dCSS LNB? There is no way to have a second cable as the existing cable runs into the extension and is buried within a wall. Therefore I need to have a single cable installation.
I would appreciate any help!
Abayomi
I do not believe that Stacker-Destackers work with the Sky Q system. I have a single feed system fro Sky Q but it comes off a multi switch via an adaptor which takes four feeds off the multiswitch and converts to two separate Sky Q feeds I only need one
But in you case you only have a dual LNB
So the options are as I see it
1) The Sky installer to fit a Sky Q LNB and rerun the dual cables required to the location of the Sky Q box some how! . Which you basically have said you do not want or
2) remove the stacker -destacker from the cables in the house
Join the two cables where the Stacker-Destacker was so you have two cable runs
fit a Universal dCSS LNB at the dish. This will use a single cable so you just find the correct LNB feed one from pair that runs to where your Sky Q box is. Change the Sky Q box to single feed and you should be ok.
Like I said I use single feed and it was not an issue for the Sky installer. I had prepared all the cables etc beforehand. In your case if you have the Universal dCSS LNB pre-installed then get them to fit crimped connectors on the cable join where the Stacker-Destacker was to give the best "join" as you do not want to run new cables!
Have a look here they describe in more detail what I have written
Sky Q with a Single Cable from the Satellite Dish
