Sky Q satellite aerial split?
Discussion in 'Sky Digital TV Forum' started by skyboy, Mar 6, 2018.
    1. skyboy
      skyboy
      Jan 17, 2011
      Hi. I Don't know if this is at all possible but here we go. I am moving to my mother in laws next week. We both have sky Q. I am keeping my subscription seperate to hers but sky cant fit the new dish/lnb for 2 weeks. Is there any way i can split the satellite cable coming in to connect to both boxes while i wait for the install or not?
      Thanks in advance.
    2. logiciel
      logiciel
      Feb 2, 2008
      53,160
      UK
      +5,788
      Sky are going to allow two accounts in the same house?
    3. skyboy
      skyboy
      Jan 17, 2011
      Yes. I am having a second phone line and a new dish being fitted to the attic room.
    4. logiciel
      logiciel
      Feb 2, 2008
      53,160
      UK
      +5,788
      There's a first for everything then!
      You can't split the cables but could use one for each.
    5. kevkbuk
      kevkbuk
      Jan 27, 2011
      5,991
      +1,176
      Do the FBC tuners have a single cable mode? How does that work???
    6. logiciel
      logiciel
      Feb 2, 2008
      53,160
      UK
      +5,788
      Good question.
      Maybe they need both in which case my idea won't work.:rolleyes:
    7. kevkbuk
      kevkbuk
      Jan 27, 2011
      5,991
      +1,176
      No, it won't. :D
      One cable provides the full band (high and low) for vertically polarised channels whilst the other provides the full band for horizontally polarised channels.
    8. logiciel
      logiciel
      Feb 2, 2008
      53,160
      UK
      +5,788
      I've had it for 18 months and didn't know that!
    9. TJT1
      TJT1
      Jul 29, 2011
      4,824
      East Sussex, UK
      +1,139
      Pull out one of your cables, see what happens and report back.:D
    10. grahamlthompson
      grahamlthompson
      Aug 3, 2006
      24,618
      Redditch
      +4,208
      As there is no control signals involved, a straight forward splitter with the correct direction power pass on both cables might actually work.
    11. skyboy
      skyboy
      Jan 17, 2011
      Ok thanks What would you suggest I use?
    12. grahamlthompson
      grahamlthompson
      Aug 3, 2006
      24,618
      Redditch
      +4,208
      You could try a pair of these. Note both boxes will provide power as both are the same 12V so shouldn't be an issue.
      Labgear 2-Way Splitter with Power Pass All Ports
      The only reason you can't split a satellite feed is down to the band and polarisation switching signals. There is none on a Sky-Q box which is why it can feed multiple tuners on just two cables so a single Sky-Q box internally splits the feeds (possibly with internal amplifiers to eliminate the splitting losses.
    13. kevkbuk
      kevkbuk
      Jan 27, 2011
      5,991
      +1,176
      How does it select either or H or V for each feed?
    14. jont
      jont
      Apr 8, 2002
      4,354
      near Aylesbury
      +581
      Am sure the LNB has multiple f-connector output feeds, so from a single dish you can run two sets of twin cable, one to each box ?
    15. kevkbuk
      kevkbuk
      Jan 27, 2011
      5,991
      +1,176
      No, the Sky Q LNB has two outputs, the customer can request the six output hybrid LNB that can run standard sat receivers in addition to Q but it is not installed as standard.
