Sky Q remote set up to control Quad Vena amp volume
BestBugsy
I have set up my Sky Q remote to operate the volume and mute functions of previous Naim, Marantz and Cyrus amps. However, my latest flame - Quad Vena 2 Play - will not play the game. The Sky set up routine and suggested codes do not let the Q remote control volume/mute. Has anyone done this with a Vena? If so, what code set (4 digits) worked for you?
logiciel
Hi and welcome to the forum.
What type of remote control does the machine use and is it compatible with Sky Q?
BestBugsy
Thanks logi.
To clarify; the small remote that comes with the Vena 2 does not control any of the Sky Q functions, just the amp. It has a small window on the front edge which may therefore be infra red, but I know not. My previously used Cyrus One remote had a small bulb like structure on the front which may also therefore have been IR.
The Sky Q remote has no visible bulb or window so I don't know how it signals the Sky Q mini box. But in theory it can be programmed to control the volume (and mute) on most amps. But not yet the Vena...
