Question Sky Q on a 1080P TV
Discussion in 'Sky Digital TV Forum' started by Alps, May 16, 2018.
  1. Alps
    Alps
    Jul 30, 2010
    2,934
    +438
    Hi guys,
    Will Sky Q work on a 1080P TV? I have a Philips 21:9 ratio TV and so do not want to change.
    Also, I’m currently running my Sky+HD via my old Onkyo TXNR 3010 AVR ( Onkyo | TX-NR3010 ) and HDBaset. Will this cause any issues with Sky Q?
  2. dts
    dts
    Jul 7, 2005
    2,074
    3
    116
    Mansfield,Notts
    +1,809
    The standard sky Q 1tb box is the 1080 version, but still only outputs at 1080i.
  3. Alps
    Alps
    Jul 30, 2010
    2,934
    +438
    That’ll do for for me as even though my current sky box is HD I only get 1080i.
    And in terms of audio, will I be able to use my current Onkyo AVR and output Dolby digital?
  4. dts
    dts
    Jul 7, 2005
    2,074
    3
    116
    Mansfield,Notts
    +1,809
    Yes both the sky +HD box and sky Q 1tb box will output Dolby digital via hdmi, or optical.
  5. Alps
    Alps
    Jul 30, 2010
    2,934
    +438
    Even though my AVR isn't 4K compatible? It also does not have HDCP 2.2. Will this be an issue with dolby digital output using Sky Q?
  6. kevkbuk
    kevkbuk
    Jan 27, 2011
    5,987
    +1,168
    The 1TB box is not 4K capable so HDCP 2.2 is not an issue, the dolby digital output will be fine.
    Only the 2TB box supports 4K and that needs the multiroom subscription to enable it, at which point you do need 4k capable gear to view 4k content as the boxes do not downscale 4k to HD resolution.
  7. Leelo55
    Leelo55
    Nov 8, 2017
    58
    Shropshire
    +12
    I have a 2tb box and it most certainly can downscale to 1080 this is a manual setting
  8. Alps
    Alps
    Jul 30, 2010
    2,934
    +438
    Thanks guys. If haggling with them fails, I'll cancel and resubscribe under my wife's name as a new customer and get sky q.
  9. TJT1
    TJT1
    Jul 29, 2011
    4,582
    East Sussex, UK
    +1,055
    I think that they might recognise the address.:D
  10. Alps
    Alps
    Jul 30, 2010
    2,934
    +438
    Haha! But apparently you can do this from what I've been told.
  11. kevkbuk
    kevkbuk
    Jan 27, 2011
    5,987
    +1,168
    Unless there's been a very recent change they do not downscale 4k to 1080. If you try and view 4k whilst on the 1080 settings it prompts you to change setting. They can upscale 1080i broadcasts to 1080p for some reason...
    It has worked in the past :D
  12. Leelo55
    Leelo55
    Nov 8, 2017
    58
    Shropshire
    +12
    I’ll try this today when I get home
  13. Alps
    Alps
    Jul 30, 2010
    2,934
    +438
    leelo55 did you manage to try it? If so, how did it go?
