Sky q Mini Box to Sound bar via Optical cable doesn't work
MikeMorris
I'm trying to connect Sky Q Mini box's to sound bar via optical cable but it doesn't seem to work, it gives noise. Connecting sound bar to tv via optical cable works so optical cable seems to be working.
Does optical out work on Sky Q Mini Box? Is there any settings to change? Anything else to check?
Rodders53
Soundbar doesn't accept Dolby so I had to turn off that in the settings. No need to run diagnostic.
Step 3 of that diagnostic shows
download
that the default is HDMI normal and Optical Dolby...
So it should have helped point you in the right direction?
I'll not bother trying to help next time. :mad:
