Sky Q keeps deleting stuff I record
Discussion in 'Sky Digital TV Forum' started by Lewiee, Dec 17, 2016.
  1. Lewiee
    Lewiee
    Sep 27, 2006
    831
    Folkestone
    +57
    Well I'm not that impressed with this sky Q. Everything seems to need downloading. On my old BT box I rarely used my allowance but Sky just eats it up in a few days meaning I've had to be moved up to unlimited. Also programs just disappear randomly. Intelligent I don't find it, or maybe that's just me:-D
  2. paulyoung666
    paulyoung666
    May 4, 2006
    13,510
    Teesside
    +3,841
    You have completely lost me , if it's not live then of course it needs to be downloaded , as for stuff being deleted , some programmes will be deleted automatically ...
  3. Lewiee
    Lewiee
    Sep 27, 2006
    831
    Folkestone
    +57
    I thought if I downloaded something it would stay there till I deleted it, or if I'm halfway through something then go back to it later I have to re download it. It just doesn't seem as user friendly as my old BT box.
  4. paulyoung666
    paulyoung666
    May 4, 2006
    13,510
    Teesside
    +3,841
    So , are you saying that you could download something now and it's gone in an hour , if it is then that's weird , have you tried a full reset of the box ?
  5. Jek99
    Jek99
    Aug 24, 2013
    468
    63
    +303
    Some downloadable programmes have an expiry date. (if so it will be stated in the description) I've never known a programme without an expiry date to be deleted unless the box is full.
  6. invisiblekid
    invisiblekid
    May 10, 2009
    4,817
    4
    +3,716
    If you download something from the terrestrial channels, they all have time limits. Some greater than others. Sky channels have limits too, but not as many.
    And if your downloading LOTS, then it could be that the oldest programs are being deleted to make room for the new ones.
    Are you with BT for broadband? If so then your BT TV was not part of your download limit.
    Also, if you record a program rather than download it later, it'll always be on the box.
  7. Lewiee
    Lewiee
    Sep 27, 2006
    831
    Folkestone
    +57
    Hi thanks for all the replies. No I've gone over to sky for all. Perhaps I am getting confused. I presumed if you download something it stayed om the box until you deleted it.
  8. logiciel
    logiciel
    Feb 2, 2008
    53,117
    UK
    +5,765
    It does.:(
  9. TJT1
    TJT1
    Jul 29, 2011
    4,711
    East Sussex, UK
    +1,108
    Is that just for 'pull' downloads, or does it include 'push' downloads Logi?
  10. logiciel
    logiciel
    Feb 2, 2008
    53,117
    UK
    +5,765
    What's the difference?:(
  11. TJT1
    TJT1
    Jul 29, 2011
    4,711
    East Sussex, UK
    +1,108
    I don't know. In my ignorance, I used the expression 'pull' as stuff you explicitly download/record and 'push' as the stuff that Sky 'automatically' downloads onto your box for your possible future viewing delight.
  12. logiciel
    logiciel
    Feb 2, 2008
    53,117
    UK
    +5,765
    I pull a lot but ignore the push!
  13. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,600
    Oxford
    +1,335
    Wrong
    There are basically two types of download
    1 Those the viewer initiates from the catchup/on demand section via the internet connection- the "pull" downloads
    2 The downloads from the satellite (the old "Anytime" service) which only stay on the box for a month or two (depending on box type - size of Anytime reserved space) unless "recorded" to your planner - the "push" downloads.
    Both types can and do have "deletion dates" varying from 30 days up to a year and more (I have Star Wars - The Phantom Menace in my planner recorded from Anytime download on 4th Dec which will auto delete on 30 Sept 2017). Even recordings from the EPG can and very occasionally do have deletion dates - I have only seen this twice so far.
  14. logiciel
    logiciel
    Feb 2, 2008
    53,117
    UK
    +5,765
    OK - I ignore 2.
