Sky Q installation question
amocs
Joined
Feb 8, 2005
Messages
11
Reaction score
Points
28
I have an original Sky SD box installed (for over 30 years now).
If I wanted to upgrade to Sky Q, I realize that the dish and/or LNB would need to be changed, but would the cable from the dish to the receiver need replacing?
TIA
How many cables are there from dish to box location ?
Just 1 cable
I did see a Sky Q installation video that explained how to connect the main receiver with either 1 or 2 cables.
TIA
Must be an antique nowadays! They run a shotgun cable nowadays, but even if not strictly necessary, if your cable is also 30 years old then I would get it replaced anyway.
Thanks.
The problem for me there is if I have to have the cable replaced I wouldn't be able to get Sky Q installed until the lockdown finished.
Just 1 cable
That's probably in a communal system where a dscr router is fitted (digital single cable router )
Thanks.
Could you pull the cable through yourself? I pulled mine through my roofspace and down existing telephone wall ducts. A much tidier job than Sky would have done.
Thanks Graham, that's an interesting article.
There's a section there that seems to suggest that it's possible in a non - communal system.
Is Home Theater DEAD in 2024?
Back
