Sky Q hybrid lnb
Discussion in 'Sky Digital TV Forum' started by milesyboy1, Jun 11, 2019.
  1. milesyboy1
    milesyboy1
    Apr 30, 2006
    586
    28
    St.Helens
    +38
    Just a quick question and probably a straight forward answer for someone in the know
    Had sky q fitted with a hybrid lnb. In room 1 sky q fitted. In room 2 kept the leads with sky hd (unused as just plugged in a mini box to the tv). After getting a new tv I switched the sky q box to room 2 using the leads formerly used with sky hd. I didnt touch anything on the lnb.
    The sky q box works correctly, however, would there be any impact on Uhd? If not then why would a hybrid lnb be needed?
    Really interested in knowing how this functions if anyone can explain. Thanks
  2. Atavus
    Atavus
    Mar 25, 2004
    449
    46
    Berks
    +182
    It’s some kind of magic. I haven’t seen it explained on here, but the Sky Q box makes itself known to the LNB.
  3. milesyboy1
    milesyboy1
    Apr 30, 2006
    586
    28
    St.Helens
    +38
    Thanks for the reply. So it doesn't matter which output the sky q box is connected to it will act the same as any other whilst it's connected? Cheers again.
  4. JayCee
    JayCee
    Jan 20, 2004
    23,905
    Lanarkshire
    +2,594
    Try recording two programmes on different channels while watching a third one.
  5. ChuckMountain
    ChuckMountain
    Oct 5, 2003
    6,324
    +1,278
    Sky q has 12 tuners so what would that do?
  6. JayCee
    JayCee
    Jan 20, 2004
    23,905
    Lanarkshire
    +2,594
    Possibly not work (?) due to the OP having his Q box connected to a standard feed from the LNB rather than the wideband feed.
  7. kevkbuk
    kevkbuk
    Jan 27, 2011
    5,989
    +1,173
    The hybrid LNB has six outputs that work in three pairs. They can all run either universal (high/lo H/V etc) mode or full band mode for Q (one H one V) with the Q box using a control signal/voltage to toggle the mode.
    • Like Like x 2
    • Agree Agree x 1
    • List
  8. TJT1
    TJT1
    Jul 29, 2011
    4,790
    East Sussex, UK
    +1,127
    If that wasn't the case, then OP's shift around would have ended in failure initially.
  9. JayCee
    JayCee
    Jan 20, 2004
    23,905
    Lanarkshire
    +2,594
    There you go, me, the OP and others have learned something this morning about the Sky Q Hybrid LNB.
  10. Atavus
    Atavus
    Mar 25, 2004
    449
    46
    Berks
    +182
    The hybrid one.
  11. milesyboy1
    milesyboy1
    Apr 30, 2006
    586
    28
    St.Helens
    +38
    That's great, thanks very much for the explanation.
