Quantcast
Sky Q HDR... When?
Roohster
I've been reading the SKY forums but even there nobody seems to know when HDR will be added.
I know a couple of SKY people use AV Forums, so I wondered if anyone knew anything?
HDR was supposed to be rolling out "late 2019", and it's about as late 2019 as you can get :p
Russ_64
I know - I have been on the Sky User Forums but there is no info there, even from some insiders who previously knew what was coming.
I have the 2TB v1 box (ES140) and running the firmware status info, it tells me that my box is not able to do HDR. If you have a v2 you can try it.
http://192.168.0.xx:9006/as/system/information (change the IP address to the one of your Q box)
There was a rumor that a new box was being tested but this has never been confirmed.
rs101
That firmware page is a little misleading - it used to say uhdCable:false with the original firmware. It just shows what the box is able to output, based on the firmware and enabled features.
Sky Italia customers have the same V2 box as many UK customers (with additional tuners) and they have HDR support.
The new 1TB box has HDR (not enabled yet) too.
Rumours are that the original v1 box won't do HDR and will need replacing. That may explain some of the delay - the V2 has a compatibility issue with some TVs and they may want that resolved before swapping them out, if that's necessary.
insider
The Sky Q 1tb box has HDR capability as well as being UHD capable too. A step in the right direction. I imagine it'll be on the next iteration of the 2tb box.
rs101
The Italian box is the same as the current UK V2 2TB box and that does HDR, so it's incredibly unlikely that the UK V2 doesn't also.
tom 2000
As Sky charges extra for everything I reckon the Marketing Dept have been told go find a ploy to charge extra for HDR and the resulting silence explains the delay.
Roohster
Thanks, it says HDR Capable: False :(
I guess they'll be replacing a lot of boxes... unless they can do it with a firmware update. I've got the V2 box so fingers crossed (if it ever happens)
I think they'd be in trouble as they advertised HDR as part of the Q/4K package.
They need to pull their fingers out, now that Amazon is broadcasting premier league games in HDR it makes SKY look bad.
rs101
The V2 boxes said uhdCapable:false until they enabled UHD support (via firmware and entitlement changes on the card) so the data on that status page doesn't actually help much.
Toon Army
I may drop Sky Cinema if I have to change my box and just rely on Netflix and Amazon Prime for my HDR films. Certainly not paying any extra.
iangreasby
There is a post today on Sky's own forum (by a Sky employee) that HDR is unlikely to arrive before the end of 2020. Sad but true.
Similar threads
