Question Sky Q dish, Sattelite cables, Samsung TV with Freesat Tuner built in how?...
Discussion in 'Sky Digital TV Forum' started by Maniac618, Aug 21, 2018.
  1. Maniac618
    Maniac618
    Jan 7, 2004
    837
    28
    +26
    Hi all,
    I have a Sky Q dish and I have the cables from the dish to my TV room.
    I have a Samsung KS8000 with a connection for a Sattelite Main cable and a Sattelite Sub cable and Freesat Receiver built into the TV.
    Do I need a DiSEqC at all, or will it just work does anyone know?
    Will I get all Freesat channels or just half? I was reading that the Sky Q Dish works differently to traditional quad LNB.
  2. kevkbuk
    kevkbuk
    Jan 27, 2011
    5,987
    +1,168
    If its the standard Sky Q LNB with two ouputs it will not work and will need replacing with a universal LNB. If it's the hybrid Sky Q LNB with 6 outputs it will work just fine.
  3. Maniac618
    Maniac618
    Jan 7, 2004
    837
    28
    +26
    Thanks for that info, I'll try and have a look from the ground when I'm home as to what's on the dish.
