exfordy
We are considering Sky Q. The main TV would be in the lounge on a wall behind which is the garage. This would allow all the cables to go through the wall into the garage and the main Sky Q box to be in the garage, out of sight.
The second TV is in the kitchen on a stud wall which has the cables inside coming out behind a sideboard. The secondary wifi Sky Q Mini box would be inside the sideboard, out of sight.
Is the main Sky Q box capable of having a feed from a 'magic eye' remote control sensor which could be fixed to the bottom of the lounge TV? Is this an unnecessary consideration as the Sky Q touch remote is Bluetooth enabled? I.e. will the Bluetooth work through the wall?
Presumably the secondary Sky Q Mini box being wifi can readily be in a cupboard out of sight?
