It's a fig8. I repositioned by block to make it easy to hard resetFigure 8. Then again you might get a v2 with external power block. That might be figure 8 into power block. I must check that.
So just to confirm, it's figure 8 in the back of the Sky Q box regardless of version?It's a fig8. I repositioned by block to make it easy to hard reset
Yes that is correct.So just to confirm, it's figure 8 in the back of the Sky Q box regardless of version?
Cheers for the confirmation. That'll make things a lot easier.Yes that is correct.
I only know if this since I've had all three versions of the sky Q box since February!!Cheers for the confirmation. That'll make things a lot easier.
Is the power block to Q not a different connection?Yes that is correct.
That’s what I thought. I haven’t seen my final connection, only felt it when rummaging in the back of my cabinet.It's a fig of 8 to V1 & V3 boxes and a fig of 8 to the power brick of the V2 which then plugs into the V2 Q box via a proprietary connector.
How big is this power brick? If I get a V2 then maybe I'll have room for the power brick behind the Q box on the rack shelfIt's a fig of 8 to V1 & V3 boxes and a fig of 8 to the power brick of the V2 which then plugs into the V2 Q box via a proprietary connector.
