Question Sky Q and BT Smart Hub (HomeHub 6)
Discussion in 'Sky Digital TV Forum' started by interbear, Dec 15, 2016.
  1. interbear
    interbear
    Mar 22, 2007
    1,176
    +171
    Does anyone have this combination?
    I've heard that Sky Q will not work if hardwired via Ethernet cable into the BT router. And that wifi connection is the only option in this scenario.
    As my BT router sits next to and is hard wired to my current Sky HD box I'd assumed that if I upgraded to Sky Q I could do the same. I'd prefer not to have it connected via wifi.
    Anyone else tried this?
  2. snowy2004
    snowy2004
    Feb 2, 2004
    1,209
    63
    Prestatyn
    +114
    I am using BT Infinity with the new Homehub 6 and it is hardwired via Ethernet to my main Sky Q box and uses WiFi to connect to the minis - works a treat :)
  3. jont
    jont
    Apr 8, 2002
    4,334
    near Aylesbury
    +577
    Having had Sky Q fitted this morning there is an option in the setup to configure a) for a wired or wireless connection and b) for Sky broadband or another broadband provider ... so wired and BT for me no probs :)
  4. snowy2004
    snowy2004
    Feb 2, 2004
    1,209
    63
    Prestatyn
    +114
  5. interbear
    interbear
    Mar 22, 2007
    1,176
    +171
    Indeed. Good advice. I've done that already as it was causing problems generally...
