Sky > Projector Help
Discussion in 'Sky Digital TV Forum' started by Lemmy, Jun 23, 2004.
  1. Lemmy
    Lemmy
    Hi Guys this is my first post on here so please go easy on me if I'm in the wrong place.
    My problem is with connecting my Sky Digibox (Panasonic TU-DSB30) to a Digital projector.
    At the moment the only way I have connected the two is by using a £5 Scart > S-Video/Composite adaptor (with in/out option) using the RGB enabled Scart 1 of the Digibox. Unfortunatley the only colour picture I can get on the projector is by connecting the Yellow COMPOSITE which I'm sure your aware is far from ideal PQ.
    If I use the S-Video ouput and connect that way, I do receive a picture on the projector but it's Black & White and mottled, I believe thats because the Digibox has no native support in the options for S-video output.
    So can any of you guys perhaps a way of getting the RGB out of the digi scart into the projector in a cost effective way, or some other way of improving the PQ. Surely it can't really be THAT hard (I'm hoping I'm missing the obvious). The projector is around 7 meters of cabling away.
    I've already got the PC Connected using DVI and the DVD connected using S-video with no probs and am happy with the PQ for those.
    Ian
    Specs:
    Digibox - - - 2 Scarts (RGB on 1)
    Projector - - - RGB (RCA Component) , DVI , VGA , S-Video , Composite.
    DVD - - - Scart, RGB (RCA Component) , Composite.
  2. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Lytham St Annes, where people are put out to grass
    What projector have you got
  3. Lemmy
    Lemmy
    The projector is a Vivitar DP-1500 which so far I'm happy enough with and has all the inputs you could ask for .. still can't get a decent PQ from the Sky box though :mad:
  4. lonestar
    lonestar
    Jul 26, 2001
    182
    maghera, n.ireland
    +4
    one possible solution is to use a scart cable from the digibox into one of these and then take a component cable from the convertor box to your projector, assuming your projector can take component input. it will mean spending some cash which might be not be appealing.
  5. Zone
    Zone
    Jun 24, 2001
    6,747
    Barnsley
    +2,441
    The JS Technology one's are considered the best, however if cost is an option there is also this one that some people have used with good results.
  6. Lemmy
    Lemmy
    Many thanks guys ... I'll look into one of these options....
    Just one thing thought does S-Video give a noticeable improvement on composite .
    I ask this as perhaps the cheaper S-Video box might just be enough for me as I'll only be using it for Sky, which as most of you have written about doesnt give a very high quality output anyway.
  7. Zone
    Zone
    Jun 24, 2001
    6,747
    Barnsley
    +2,441
    Svideo gives a much improved picture over composite. The picture offered by Sky can be quite bad at times so why exacerbate it, I'd go with svideo as a pure minimum :)
  8. robbo24.
    robbo24.
    you could buy a secondhand grundig digibox with S video output.
