SKY+ programme disappearing!? Help please!
Discussion in 'Sky Digital TV Forum' started by Pacha, Sep 21, 2005.
  1. Pacha
    Pacha
    Oct 29, 2002
    134
    During the recent EPG update to sky a programme i had recorded a while ago, and preserved with the 'keep' button has disappeared.
    Does anyone know of any procedure that may be done to retrieve the programme, and /or what causes this in the first place? Is it a common occurence or do i have a faulty SKY+ box?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    You could try a planner rebuild but most of the time if it's gone then it's gone.
    Services
    4
    Select
    SKY+ Planner Rebuild
    *At your own risk*
    Assuming the SKY+ has not deleted it (and it shouldn't hence the KEEP) under normal disk managment it may have been deleted as a corrupted recording. When the SKY+ boots or reboots it does a check on the drive and removes anything it considers suspect, this may have happended in your case.
