sky probs
Discussion in 'Sky Digital TV Forum' started by nigelcraft, Jul 8, 2002.
  1. nigelcraft
    nigelcraft
    Mar 18, 2001
    87
    uk
    i cant get some of my channels to work on my sky digital,a selection of channels which used to work fine ie the box ,smash hits etc now wont work and say not recieving signal,have tried the reset thing by turning off sky at plug removing card and switching back on and all that stuff but it still wont work ,ive got a grundig model which ive had since sky digital came about,i cant afford an engineer and while the channels i cant get are not that important , some i used to like watching and it really irritates the hell out of me,any got any idea what to do? or am i buggered:confused: :confused:
  2. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    I think your dish may have gone out of alignment. I say this because the music channels are the weakest of all the channels, and are thus the first to go when your signal degrades. :(
  3. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Lytham St Annes, where people are put out to grass
    Not that I would know (as I have yet to have sky installed (2 weeks to go and then Mr Murdoch will have me in his clutches). but Lex might. Maplins sell a satellite signal thingy for a reasonable amount (£40). Would it not be a worthwhile investment to buy one and align it yourself. It would pay for itself after one alignment. I cant believe that it is that skillful a job as I dont recall satellite installation being on offer as a subject at school or college.:D
  4. gges
    gges
    What make is your receiver?
  5. nigelcraft
    nigelcraft
    Mar 18, 2001
    87
    uk
    its a grundig
  6. gbmitie
    gbmitie
    Apr 25, 2001
    1,166
    49
    republic of ireland now
    +70
    check the sat lead at the back of receiver, it may have come loose and if u can check lead into LNB, or do u have any major kinks in the cable that were not there before.
    gbmitie
  7. qfk123
    qfk123
    Mar 11, 2002
    1,071
    +91
    OMG
    thats happened to me a few times, certain channels namely ITV, Disney and few of the music channels stop working ie, can select them but blue screen and banner , after few moments it say no sat signal being recieved, i just checked em now and there working fine, but its happened on and off ,
  8. nigelcraft
    nigelcraft
    Mar 18, 2001
    87
    uk
    various channels still off all the time,have given up now and resigned myself to the fact that im stuck with the problem as i cant afford to spend money on getting it fixed ,luckily the main channels are ok,have done check after reset after check ,fed up with it now so im now officially giving up
  9. Paul G
    Paul G
  10. Kentish
    Kentish
    Jun 15, 2002
    23
    I had a similar problem.
    The guy who installed my set up came back,and had to replace the LMB on the dish.He has had a batch lately like that apparently,but Sky dont want to know.
