Sky + problems
Discussion in 'Sky Digital TV Forum' started by umeerw, Dec 26, 2006.
  1. umeerw
    umeerw
    Aug 1, 2006
    122
    16
    Had sky for 2 months no probs, today the fan wouldnt stop for about 2 hours then the remotes started playing up, now they just dont work, also all the multi links dont work either, have picture and sound no probs on all tv's but need to use buttons on front of box to change channels and even thats tempremental. called sky did a back thing switched the rfs off and on, but still no remote work (yes i've changed all batteries). ANy ideas, sky engineer coming on the 8th of jan.
    cheers guys.
    umeer,
    syandard sky+ box, no upgrades, can still access HD for saved programmes.
  2. FRANTIC FRANC
    FRANTIC FRANC
    Aug 7, 2006
    1,375
    63
    +86
    Hummm! Are the 'TV guide' 'Services' 'Box Office' 'Interactive' buttons blue or green? May have a fix for you if they are blue!
    Cheers, Franc
  3. umeerw
    umeerw
    Aug 1, 2006
    122
    16
    they are blue frank! what are you thinking??
    umeer
  4. FRANTIC FRANC
    FRANTIC FRANC
    Aug 7, 2006
    1,375
    63
    +86
    The RCU's with the blue buttons seem to play up quite a bit.
    Try pressing:-
    TV
    yellow & select (rcu blinks twice)
    select
    Sky
    See if that gets it working again. Cheers, Franc
  5. umeerw
    umeerw
    Aug 1, 2006
    122
    16
    thanks, frank, i'll try that when i get home!!
