Sky+ Problems
Discussion in 'Sky Digital TV Forum' started by Drewnet, Jan 23, 2002.
  1. Drewnet
    Drewnet
    I would just like to know if anyone else is having problems with Sky+ like me.
    I had it installed last November and am now on my 3rd box. This one works for about 4 minutes before locking up and I have to unplug it and try again but every 4 minutes or so, it locks up again.
    I now have virtually no Digital TV at all, and have had to revert to sticking an old tv ariel on top of my TV.
    Any opinions?:(
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    I bought my SKY+ from Currys back in September and apart from one month when I had numerous failed recordings it has been very good.
    Haven't had a failed recording or needed to reset the box for a couple of months now.
    Get in touch with SKY and tell them to take it back and refund your money, three boxes on and you are still having problems is disgraceful or just real bad luck.
  3. Chippy99
    Chippy99
    Nov 16, 2000
    1,378
    116
    Bristol, UK
    +518
    Drewnet, just to echo Starburst's comments:
    I got my Sky+ box in mid December. I have had no problems with it whatsoever; no noisy harddrive, no failed recordings, no lockups, nothing. Its just been plugged in, switched on and left to work. I have been thoroughly delighted with it.
    Get yours replaced again!
    Chip.
  4. tk212
    tk212
    Ive had no problems whatsoever with mine, had it installed last October and I'm absolutely delighted with it.
    Ill be uinstalling a 120Gig next week when it arrives too so 70+Hrs of recording here I come :)
    Phil
  5. Taz
    Taz
    tk212,
    I thought 80 Gig was the max size DIY upgrade for Sky+ as when it powers up it takes to long to check the drive and initiate it:confused:
    Taz.:cool:
  6. tk212
    tk212
    Taz,
    Theres one certain model of 120Gig by Maxtor that will slot in no problem whatsoever. Theres another thread i started about the possibility of upgrade, and some people put links in there, which is what i followed,one to a forum thread which is very interesting...
    Ive now installed my 120Gig and it is filling up nicely :cool:
    Very happy indeed
    Phil
  7. Taz
    Taz
    Well done Phil,
    that sounds great, whats the model of the 120Gb drive?
    Taz.:cool:
  8. tk212
    tk212
    Hi again Taz,
    Wasnt at home before, so didnt post the model number..
    Its a Maxtor 120Gb 4G120J6 5400rpm.
    Slots in fine, has the usual problems with the numerical space indicator:rolleyes: but seems to be OK so far :)
    Phil
  9. Taz
    Taz
    Thanks Phil,
    sorry.... any idea of price;)
    Taz.:cool:
  10. tk212
    tk212
    Taz,
    Umm, mine i managed to get through work tax free , but theyre going in most places for around £200...
    try www.scan.co.uk , i think theyre around £204 ish may also find its called the D540X 120Gb but make sure you get the 5400Rpm version.
    Phil
  11. Taz
    Taz
    Thanks Phil.;)
    Taz.:cool:
  12. Drewnet
    Drewnet
    Well after two weeks of hounding Sky, I finally received a 4th new box on saturday and so far so good.
    At last I can start to record stuff and fill up the box without having to worry that it might be taken away again.
    I don`t think I`ll be messing with the hard drive as I,m just glad to have it working. :)
