Sky+ problems
Discussion in 'Sky Digital TV Forum' started by Steveford77, Feb 26, 2005.
  1. Steveford77
    Steveford77
    Feb 26, 2005
    17
    Tonbridge
    My sky+ is knackered! Picture keeps freezing, very jerky and mostly unwatchable. The Sky help desk want me to reformat hard disk, which i will do when I have archived some old stuff - its only new recordings that don't work. If I still have the problem after format is it likely to be a hard disk problem? In which it'll be cheaper to replace hard drive than call out engineers.
    Any views?
    Steve
  2. Blu Ray
    Blu Ray
    Jun 14, 2004
    496
    Chorley, Lancs
    +12
    Almost certainly an HDD problem I'd say, and yes you're right, it will be more cost effective to plug in a new (& bigger) drive.
  3. shoestring25
    shoestring25
    Feb 2, 2003
    4,576
    essex
    +898
    mine did exactly the same thing it was the hard disk. i put in anew bigger one my self as the warrenty had expired. i put in a 160gig one £55 problem solved. runs as smooth as you like no problems also i now have a huge recording capacity the box is also quieter now than with the original harddrive.
    now i realise i should have done it ages ago
  4. NC11
    NC11
    Sep 19, 2004
    468
    London
    +7
    I've upgraded my box to a Maxtor 5A250J0 250GB about 2 months ago. All was working well , and I filled more than 20% of the capacity with recordings.
    Since last week I'm having a nightmare with new recordings! :mad:
    Although it seems to record , when I'm trying to watch it , the picture freezes after 30 seconds and will not continue. On some recordings it will play another 30 secinds and freeze again , on some it wont do anything.
    Not sure what to do now , as I dont want to lose all my recordings! :confused:
    Any suggestions?
