Sky + problems recording only one channel
Discussion in 'Sky Digital TV Forum' started by knaggsy, May 30, 2005.
  1. knaggsy
    knaggsy
    Hi i was wondering if anyone can help me. When i try to record manually and using the record button it only seems to tape one channel one i watched a few days ago. All programs recorded are the same channel. Has anyone had the same problem.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    The manual recording option lets you specify the channel you wish to record along with the start and stop times so it'll record what you tell it too.
    If you just press the "r" button then it will record the channel you are currently watching (within the time frame of the current programs EPG info).
    If you want to record a program on a different channel and/or time using the limited search & scan banner just make sure when you press the "r" button it appears on the program you want and not after the banner has timed out.
