Sky + Problem
Discussion in 'Sky Digital TV Forum' started by bobbles, Aug 1, 2003.
  1. bobbles
    bobbles
    Had my first major problem with sky+ yesterday
    I set it to record the last 15min of eastenders for the mrs
    however when I got up this morning it had recorded 14hrs worth of bbc1
    it did not record any of the other progs i set up to record later that night and even more annoying wiped over the progs saved i had not put on to keep
    anyone else have this? Is it due to sky changing bbc1 mine now says bbc1 midlands
  2. DaveP
    DaveP
    Did you do a manual recording? I did on one occasion and because it doesn't use the 24 hour clock I started at 11:00pm and ended at 12:00pm, this of course should have been 12:00am!
    I cannot see how using the planner can make it record for so long but I may be wrong.
    Dave
  3. bobbles
    bobbles
    nope it was recorded using the planner
