Sky+ Problem
Discussion in 'Plasma TVs Forum' started by mrd123, Apr 21, 2003.
  1. mrd123
    mrd123
    Jan 19, 2003
    3
    Hi all,
    A quick question to the forum, I currently have a sky+ box connected into a panny plasma using a Keene SCART to VGA cable with power supply. When I first set everything up the cable worked fine with no power until I tried watching a sky+ recorded program when the picture disappeared, to fix this I plugged in the cable power lead and it was sorted, however I have now discovered that box office shows do not work, even with the power connected :confused: Does anyone have any ideas on this?
    TIA
    MRD
  2. jont
    jont
    Apr 8, 2002
    4,266
    near Aylesbury
    +552
    Could the macrovision be interferring with the signal through the lead ... I know some plasma can be very particular about their sync signal strength ??
