sky problem
Discussion in 'Sky Digital TV Forum' started by starbaby, Aug 21, 2004.
  1. starbaby
    starbaby
    hi hope some one can help me i have just installed a sky magic eye it works ok on the second tv with the remote but when i go to change channel on the orginal tv with the remote nothing happens but works ok when you press the buttons on the box itself and dissconect the second tv the box is a pace model number 1.3.15 and version number 9f020c it is not sky+ hope someone has some ideas of what is wrong thanks pete.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Punctuation, it's a wonderful thing:)
    So the same remote will control the digibox via a TVlink device connected to RF2 but will not control the same digibox via it's front IR sensor?
  3. starbaby
    starbaby
    yes thats right starburst any idea on how to fix it
  4. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Not really:(
    My first thought would be that the IR sensor in the digibox has failed.
    The remote is obviously ok otherwise it couldn't control the digibox via the TVlink, at least that sounds reasonable although I wonder if the TVlink sensor is more sensitive and is picking up a weak signal that the main IR sensor is missing.
    Always worth replacing the batteries in a remote just on the off chance.
  5. andymc
    andymc
    Sep 18, 2003
    266
    Bedford
    +15
    Have you turned on the power to the second RF outlet? I had a similar problem with it allowing me change channels but I could not turn off the box. Go into Services and then into Sky set up (I think its option 4) then just enter 01 which gets you into command mode.... then you will see the RF Outlets option and make sure the power supply is set to ON for the second one. See if that works!
