Sky+ problem with extender
Discussion in 'Sky Digital TV Forum' started by Bobbych, Aug 23, 2005.
  1. Bobbych
    Bobbych
    Jan 30, 2002
    32
    My Sky+ system has a digi eye compatible booster/extender attached to RF2, it feeds 3 tvs, 2 with magic eyes. All work fine except for random interference, picture goes a bit snowy only on extended tvs for upto 10 seconds and am unable to use remotes. It seems to be worse in eve.
    Today i replaced the extender box for a diff model thinking it was that. but its just the same.
    Thanks in advance
  2. vex
    vex
    Mar 8, 2005
    2,905
    103
    London, Home Counties & North West
    +261
    How often does this happen?
    Could it be tracked down to interferance from something else?
    Chris
  3. Parklife
    Parklife
    Jun 9, 2004
    574
    28
    +33
    As chris says it could be interference from something. Try changing the RF channel and retuning the TVs into the new channel.
  4. Bobbych
    Bobbych
    Jan 30, 2002
    32
    Cheers guys.
    It happens more in the evening. bout every 2 to 3 mins. I recon it is intrference too but not sure how to check. supose i could run a new cable a diff route. I will try retuning rf sig too. ta
  5. SamRadford
    SamRadford
    Jul 12, 2005
    3,965
    103
    N. Yorkshire
    +308
    Probably a boiler thermostat. Notorious for that. You can get a suppressor but first you should ensure that ALL your coaxial cables are double-screened and are well away from any mains wiring.
  6. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Or interference from amateur radio or CB radio.
  7. Bobbych
    Bobbych
    Jan 30, 2002
    32
    I changed the RF frequency by 2 and it seemd to sort it. I only saw i instance of the prob last night, so will adjust again
