smarty
Established Member
Had some work done on Monday, part of which involved shortening the satellite cables and sending them into the house at a different point. The installers also put a socket on the wall so that both the leads can be plugged into it.
However, I now have a very bad signal strength on input 1 (signal quality in the middle) which means every so often the picture stutters/freezes for a split second. Input 2 has full signal strength. Prior to the cable changes input 1 strength was around the middle and input 2 just over half way.
Is there anything I can do to get the signal strength back up on input 1 or will I have to get them back out again? Sounds to me like a dodgy connection of dodgy wiring on one of the cables but not too sure what to look at.
