Sky plus with DVD recorder?
Discussion in 'Sky Digital TV Forum' started by General Panic, Nov 11, 2003.
  1. General Panic
    General Panic
    Jan 14, 2003
    721
    Scotland
    +18
    Hi Guys :hiya:
    Anyone use Sky+ with a DVD recorder , preferably the Toshiba rdxs10 and have any problems recording from box to recorder?
    Trying to convince myself £250 for upgradeing my current Sky box to + is worth it. I know the 5.1 sound will be an improvement but with the storage on my Tosh HDD i'm not sure i'll gain any other benefits.
    General Panic
  2. dts borg
    dts borg
    Sep 5, 2001
    578
    Hornchurch
    +8
    Sky + works great with my Philips DVD recorder. Never had any problems in over a year.
    Oh keep this SsShh SKY + is worth every penny! It is so good the wife has taken over my Home Cinema :suicide:
    You won't regret spending your money ;)
    Good Luck
    dts......:)
  3. ivanwilson
    ivanwilson
    Oct 31, 2003
    111
    Belfast
    Sure it's only £199 + £1 install - a lot cheaper than £250;)
    I also use a Philips recorder (DVDR70) it works great as I'm sure would all the '-' recorders.
  4. General Panic
    General Panic
    Jan 14, 2003
    721
    Scotland
    +18
    Hi Ivan
    Sky tell me £199 for the machine plus £50 installation as an existing subscriber and even another £10 if i want my current machine relocated! The £1 install is only for new subscribers.
  5. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Exisiting subscribers get the £1 install if they order SKY+ via the SKY website, if the ordering process fails then ring the number given and you'll get the web price via the phone call. I've also bee told that the existing box is relocated free of charge if you are not taking out the mirror sub.
  6. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    Sky+ 's main advantages over any dvd recorder,are the simultaneous record and watch from 2 different channels,and storage of 20 hours at broadcast quality.Only a DVDR/HDD can compare.Is the Tosh you are using one of the new ones with RGB in?
  7. General Panic
    General Panic
    Jan 14, 2003
    721
    Scotland
    +18
    No it's only RGB out unfortunatly.The 2 Sky channels at once could be useful i suppose although repeats are the name of the game on Sky these days.
    Thanks Starburst for the on line ordering info , Sky never mentioned that on the phone for some reason ;)
    Thanks for the advice guys.
    Panic
