Sadly GDPR means we can nolonger offer access to AVForums via the branded app or Tapatalk. Click here for more information.
Sky Plus Sound out of Sync!
Discussion in 'Sky Digital TV Forum' started by ajfoggy, Jan 12, 2005.
  1. ajfoggy
    ajfoggy
    Aug 12, 2004
    112
    +5
    Does anyone else have a problem with the sound being out of sync, I have noticed this since around Christmas. Changing channel rebooting doesn't resolve the issue. It's starting to get very annoying.
    Anyone any ideas?
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    What signal strength & quality do you have ? You may be getting a high error rate.
  3. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    Had a couple of isolated incidents over the last month or so - sorted themselves out after a couple of minutes though.
  4. mc1
    mc1
    we get the odd isolated incidents too and I am pretty sure it is only ever ITV1, maybe even restricted to Emmerdale or Corrie (can't actually remember which one)
  5. StevePn
    StevePn
    Nov 15, 2004
    167
    Salisbury
    +5
    tend to get it in the mornings, trisha etc.
    I turn unit off for couple of mins then ok. I have sky not plus.
    steve
  6. stevebez
    stevebez
    Jul 11, 2004
    493
    +13
    I get this too - thought it was the Surround processor etc .. but nope ... is a bit anoying. >80% for signal both channels. I do use a stacker - destacker to get my twin signal feed though...
    Rgds Steve
  7. HMHB
    HMHB
    Nov 11, 2001
    26,711
    Nottinghamshire
    +5,463
    I get it quite often on the +1 channels of UKGold and Paramount and a few others
  8. vectrasri99
    vectrasri99
    I get this and it seems to be worse via the DD output. Infact a recording I made from Movies 1 got progressivly worse as the film went on.
    What is going on, I sold SKY+ to the wife and its so so good when it works (WHEN). She is not impressed with the sounds and failures to record.
    Should I send it back?
    M
  9. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    Don't get me started on the missus - my Sky+ ONLY seems to fail on the Bill - I think this is "a right touch" but she is far from impressed.
  10. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    I have only seen this once with DD sound, and I'm sure it was Sky's problem, because it was recorded on to the HD that way, and the same every time it was played back. Apart from the usual problems with the "economy" channels (ITV2, ITV3, etc) using micky-mouse equipment, I don't get too many lip-sync errors on other channels.
  11. quizman99
    quizman99
    I frequently get it with recordings. I have found the solution is to take the power lead out of the back of the box for about 30 seconds and then plug it back in and let it reset itself. The old boxes had a problem with static and this used to cure it, it looks like it does the same for Sky Plus
  12. The Splund
    The Splund
    Nov 6, 2009
    2
    3
    Sutton Coldfield
    I've had this problem for a while and it seemed to be worse after I bought a new cabinet for my Sky+ HD box & other equipment because the Sky+ box became very hot. I've now fitted a fan to the cabinet, the Sky box is a lot cooler now & the sound issue appears to happen less often. When it does happen I have to turn the Sky+ box off at the mains plug, then turn it back on & wait about 30mins for it to come back on. FYI I've also upgraded my hard drive to a 1TB version so I'm not sure if this has also had an effect to make the sound go out of sync.
  13. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,829
    +897
    What make Sky box? (Bet it's a Thomson - Look on the forum for "Thomson", "PSU", "Bulging capacitors")
  14. CombatMoth
    CombatMoth
    Sep 21, 2011
    2
    4
    I found that I had to stop my sky rewind feature and it all went away. It was not a problem because I never used it.
  15. HMHB
    HMHB
    Nov 11, 2001
    26,711
    Nottinghamshire
    +5,463
    I'm currently suffering with this on my Sky/Amstrad HD box on C5 HD, ITV HD and DAVE HD. It does it live and recorded.
    I will try it without the rewind on to see if that makes a difference.
  16. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,829
    +897
    Given that prior to today, this subject is nearly 12 months old, how are you listening to the sound?
  17. HMHB
    HMHB
    Nov 11, 2001
    26,711
    Nottinghamshire
    +5,463
    HDMI through the telly. There are a lot of people with the same problem on the Sky Help Forum. ITV1 HD is quite often unwatchable as the sync is so far out.
  18. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,829
    +897
    It could be a TV problem. Those of us using an external AV receiver do not, (I think), see/hear, such a problem.
  19. HMHB
    HMHB
    Nov 11, 2001
    26,711
    Nottinghamshire
    +5,463
    No I don't think it's the telly. When my Samsung HD box was in that room it was fine.
  20. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,829
    +897
    I'm sorry, that does not equate. Were you using an external amplifier for the sound?
  21. HMHB
    HMHB
    Nov 11, 2001
    26,711
    Nottinghamshire
    +5,463
    No straight HDMI cable from the Sky box to the telly.
