Sky Plus RGB Question
Discussion in 'Sky Digital TV Forum' started by Johndm, Nov 22, 2004.
  1. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    Thinking of upgrading to Sky +, but need to know if the Pace box has RGB throughput, as I need to daisy chain other RGB units due to my Panny TV having just the one RGB scart connection.
    Also, is upgrading via Sky the best option, or is it cheaper to just buy and install myself, and just upgrade my subscription?
    If self buy is better, where is the best place to go out now, and actually bring the kit home in my sweaty hands.. :laugh:
    regards
  2. bobcar
    bobcar
    Oct 3, 2004
    708
    +21
    Both Pace and Amstrad have RGB out on the TV scart and RGB in on the VCR scart so you can daisy chain other units into this. There is no RGB out on the VCR scart so a DVDR would need to be in between the Sky+ and TV.
  3. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    Which is exactly where my existing Panny skybox box sits....before my DMRE60 in the chain.
    Do you know if any of the big 'chains' have Pace Sky+ to actually take home?
    And do they supply a quad LNB/cable etc or just the box?
    regards
  4. bobcar
    bobcar
    Oct 3, 2004
    708
    +21
    Argos do it for £199
    http://www.argos.co.uk/webapp/wcs/s...atalogId=2501&productId=102660&clickfrom=name
    the picture is a Pace, it doesn't mention LNB etc. It does say free installation but I'm not sure if thats still valid. Also note the normal Argos take back doesn't apply.
