Sky Plus Optical Output to Cheapo Surround Sound System
Discussion in 'Home Cinema Buying & Building' started by Hoggie, Apr 10, 2005.
  1. Hoggie
    Hoggie
    My father bought a Surround Sound system from some Supermarket expecting to hook it upto his Sky box & get surround sound. His Sky box only has an optical output & the Amp for the speaker system has the colour coded inputs, is their something that will convert the digital signal to the sperate channels needed? or will he have to fork out for a better system? I've checked all his other equipment & they're all the same
  2. gtg60
    gtg60
    Oct 2, 2003
    387
    28
    Ireland
    +36
    No good I'm afraid, you'll need an actual Dolby Digital decoder built into the surround system, unfortunately you won't find anything to fit in between to make it work (that I've ever heard about anyway).
    Just look for a surround system that has Optical in, that's your safest bet...
    Keith
